3D Design
3D Design
meshing is not properly working
    • abhay mahar
      how to remove this error. meshing is not done completely
    • Naresh Patre
      Hello Abhay,
      I see that you have specified Mapped Face Meshing. Try suppressing it and regenerate the mesh.
      Also, first try to generate mesh with default global mesh settings. Once the mesh is generated, you can modify and/or add local settings to improve the mesh as required.
    • abhay mahar
      sir i just generated meshing with default settings . but it did not worked
      then i meshed it with faced meshing but it also did not worked
    • abhay mahar
      Hello Abhay,
      sir these are two regions where meshing is not working properly . i tried default settings at first but it did not work
Viewing 3 reply threads
