Meshing Issue (Sweeping Method)
    • skdubey
      Hi Friends,
      I am having issue with the following meshing, all the part of geometry is sweepable except the give one part, it is not clear why it is so, its almost the same shape just that it is separate component and stil the mesh tool was not able to perform sweep meshing, I also use the sweep method and choose the face lateral and top and bottom but none works.
      Any suggestion??: should I defragment my geomtery more (spacecalim), doing it create more cyclic dependence and error too.
      Thanks
    • Keyur Kanade
      Please check if you can use multizone method.
      Please check following videos
      Ansys Meshing Sizing:
      https://www.youtube.com/watch?v=w4q6q8nKF3U
      Ansys Meshing: Decomposition for hex meshing:
      https://www.youtube.com/watch?v=P19GOTQWmc0
      Ansys Meshing: Meshing Methods:
      https://www.youtube.com/watch?v=nEOC8rDnnRo
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
