Meshing issues for various cross sections
    • Jan-Henrik Rieger
      Hello, I am trying to create a mesh for differently shaped pipe cross sections (inner body). In this process, fluid flows through the pipe (inner body) into an expansion volume. The middle gray body encloses the pipe and forms the transition into the outer expansion volume. I have defined the mesh of the pipe and the transition body using face sizing. The settings are the same for the two different cross sections, so only the cross section of the inner body changes. What could be the reason for the change in the mesh? Why can the mesh be structured like that in the first image, but not in the second one?
      Thank you very much in advance!
    • Keyur Kanade
      This could be due to global curvature sizing. Please change min and max of global curvature sizing funtion.
      Please go through help manual for more details
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/wb_msh/ds_Sizing_Group.html
      Please check following videos
      Ansys Meshing Sizing:
      https://www.youtube.com/watch?v=w4q6q8nKF3U
      Ansys Meshing: Meshing Methods:
      https://www.youtube.com/watch?v=nEOC8rDnnRo
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
    • Jan-Henrik Rieger
      Hello Keyur,
      thank you! that solved my problem.
    • Keyur Kanade
      You are welcome!
Viewing 3 reply threads
