Tagged: 2d-mesh, 2d-meshing, Meshing, meshing, triangular
September 5, 2019 at 8:13 pm
diana
SubscriberHi,
Im trying to meshing a real porous media. i got it the geometry and i supposed that it dind´t have errors. But when i apllied the patch independt algorithm to create tetrahedroms failed, and with others methods i cant reduce the skewnees less than 0.99. Offf course when i run the simulation it diverges. any suggestion?.
September 6, 2019 at 9:07 am
Ansys EmployeeHave a look to see where the poor cells are: chances are you have pinched geometry or small gaps. Once you identify the cause you can correct the mesh: post images if you want some pointers.
September 15, 2019 at 3:05 pm
Raef.Kobeissi
SubscriberCan you attach a picture??
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2630
2110
1335
1110
461
