Preprocessing
Preprocessing
Meshing problem
    • raju.chowdhury
      How to solve this problem of meshing?
    • peteroznewman
      Did you use Hex Dominant Method?
      If this is a mesh for CFD, ANSYS Help says, "Do not use Hex Dominant Method for CFD meshing."
    • raju.chowdhury
      Yes, I have used hex dominant method.
      Which method I should use in this case?
      Anything other than hex dominant.  What are you trying to model?
    • raju.chowdhury
      I have tried with 'mutizone' option but the meshing is failing showing the error "MultiZone blocking decomposition failed".
      So try unstructured, tets. Multizone shouldn't fail unless the "free mesh type" isn't set: use patch conforming tets.
    • raju.chowdhury
      Seems the same problem for unstructured mesh as well.
    • peteroznewman
      When you have a section view, click the button to show full elements and you will get a much more useful section. Without selecting show full elements, you are cutting through elements and making it had to see the true element shapes.
Viewing 7 reply threads
