Meshing problem in explicit dynamic
    • george10
       Hey,
      Since i do research hip prosthesis forming in explicit dynamic, i find the problem which i cant define what the solution is. Some elements meshing soared up. When i check the quality of meshing on that elements, its still in average points( not lower than average). The contact is frictional, but when i change the contact into frictionless it still happen. My input force on die is 3000MN and prevelocity in 15 mm/s. can you help me why it could happen? i will attach the picture. i use istropic (young modulus and poisson ratio), density, and johnsoncook
    • peteroznewman
      Please use the Insert Image button to put the image into the post as well as attaching it because ANSYS staff are not permitted to open attachments.
