Meshing problem in Fluent
    • mukundsunil
      Hello, I'm conducting a CFD simulation for the symmetric and cambered airfoil, 2-D simulation. I encountered a problem in the meshing of cambered airfoils. Any cambered airfoil I try to mesh I get an error saying that quad mesh has failed in one or more faces. Sometimes the meshing only fails on one or more faces.
      Below I have posted the picture of both the symmetric and cambered airfoil.
      The above picture is meshing of a cambered airfoil.
      This is that of the symmetric airfoil. I want the mesh of my cambered airfoil to also look like this. What should be done for that to happen?
    • RK
      Did you try using Body of influence while meshing?
      Rahul
    • mukundsunil
      Thanks will give it a try.
      Mukund
    • falcon18
      I am working on a similar project. But my wing attack is changing. Disorders occur when meshing. While it should be structural, some regions do not. Is there any mesh sample for the wing with 5 degree attack angle?
Viewing 3 reply threads
