Meshing Problem in Mesh program, type CFD
    • Tharathep1234
    • Karthik R
      Administrator
      Hello,nAre you seeing this error only when you are export a Fluent mesh? Or do you see this message when you are simply saving the project?nThanks.nKarthikn
    • Keyur Kanade
      Can you please use latest version 2020R2?nPlease check mesh quality. For CFD, please check orthogonal quality. The min should be more than 0.1. nAlso please provide more information as Karthik has mentioned. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • Tharathep1234
      I only got this problem when I tried to update Mesh on workbence. My mesh generating totally completed (as you can see green check mark on those meshing method).nn
      Can you check cell quality. Is it a 3d model? n
    • Tharathep1234
      Yes, it is. And I will check mesh quality. Thank you, sirn
Viewing 5 reply threads
