Meshing progress bar stops when finer mesh is used (other than default initial mesh)
    • mqasim
      I'm simulating a three phase induction motor with outer rotor and inner stator. I have tried to use finer mesh, but when I do that: refine the initial mesh or add certain mesh settings to some parts of the motor where I the field calculation accuracy matters the most, the progress bar stops at the point shown below:
      Your help is greatly appreciated.
Viewing 0 reply threads
