February 22, 2022 at 1:05 pm
PJquintanilla
SubscriberI think I have a problem with the licence. After carrying out several simulations, when modifying a mesh, nothing is generated and the window that I attach remains continuously. Do you know how I can solve it?
Thank you very much
February 23, 2022 at 4:14 pmAshish Khemka
Are you performing a Structural Analysis on Ansys Cloud? Also, it looks that you completed a few simulations but this one is giving you trouble. Is the element size too small? If yes, then mesh generation may be time-consuming.
Regards Ashish Khemka
March 7, 2022 at 8:19 amPJquintanilla
SubscriberIt was not in that sense but I thank you very much for trying to help me.
In case anyone sees it and it happens to you, the solution is given by a total deletion of the cache of the cloud platform. It is not enough just to restart the program's cache. In addition, until the computer is not restarted, it will not work.
Regards
Trending discussions- 2022 R1 What’s New PDF/PPTX?
- Prms/ pmean
- separation based debonding,CZM parameters
- Hydrodynamic diffraction and response
- The simulated results of microstrip patch antenna does not match the online example
- Desktop/laptop specification for Ansys forte
- how to simulate piezoelectric patch on ANSYS workbench ?
- Heat simulation – change source wavelength
- Mudjere
- Meshing/Simulation problem
2600
2088
1319
1108
459
