January 11, 2023 at 5:08 am
January 11, 2023 at 5:37 am
Keyur Kanade
Ansys EmployeePlease check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.Please check if you have any sharp angles or small gaps. Make sure you remove them in SpaceClaim.
If any small gap is important and can not be removed then make sure that you have applied correct sizing.
Please check following videos
Ansys Meshing Sizing:
Ansys Meshing: Meshing Methods:
Please go through help manual for more details
Keyur
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2142
1355
1144
462
