Message: Not all Named Selection were successfully written
    • SaiD
      Not all Named Selection were successfully written. How to resolve this message?n
    • Cheta Rathod
      Regarding your this query about Named Selection, it seems that . can be causing the problem. For defining names of the Named Selection, . is not supported. If you replace . with _ then it will solve the issue.nYou can also check some rules for naming them as instructed below before sending them to Mechanical APDL solver;n1) A name exceeding 32 characters is truncated.n2) A name that begins with a number, space, hyphen, or parenthesis character, is renamed to include "C_" before the character in APDL.nSpaces, hyphens, or parentheses between characters in a name are replaced with underscores in APDL.n3) Named selections starting with ALL STAT or DEFA will not be sent to the Mechanical APDL application.n
