Metal foam mesh
    • luishernandez19
      Hello, I have tried to mesh this geometry in every possible way. I have used different qualities of mesh and it always throws error at me. I did around 10 simulations with different test tubes with different porosities and this is the only one that won't let me mess. Nor do I observe errors in geometry. Any help would help me a lot! I leave the link of the geometry in case someone wants to test, it is a script. Cheers!!
      "A software execution error occurred inside the mesher.  The process suffered an unhandled exception or ran out of usable memory."
      "The mesher restarted at a higher relevance in order to achieve a successful, quality mesh."
      https://drive.google.com/file/d/1QQhc6OskzeqI1-Hgwcjz7LZiFMVN5O1q/view?usp=sharing
      It tends to mean you've got a small gap or angle somewhere that's causing the mesh to over-refine.  How big is the domain? I can't tell if the comma is replacing a decimal point.
