September 27, 2017 at 11:19 am
nselvara
Ansys EmployeeWith which methods does pinch control work?
October 17, 2017 at 7:02 am
Arun
Ansys EmployeeThe Pinch feature lets you remove small features (such as short edges and narrow regions) at the mesh level in order to generate better quality elements around those features. The Pinch feature provides an alternative to Virtual Topology, which works at the geometry level. The two features work in conjunction with one another to simplify meshing constraints due to small features in a model that would otherwise make it difficult to obtain a satisfactory mesh. When Pinch controls are defined, the small features in the model that meet the criteria established by the controls will be “pinched out,” thereby removing the features from the mesh. You can instruct the Meshing application to automatically create pinch controls based on settings that you specify, or you can manually designate the entities to be pinched. Pinch controls can be applied to solid and shell models, with certain restrictions as shown in the table below. The Pinch feature is supported for the following mesh methods: Volume Meshing: 1. Patch Conforming 2. Thin Solid Sweeping 3. Hex Dominant Meshing Surface Meshing: 1. Quad Dominant 2. All Triangles 3. MultiZone Quad/Tri More details: help/wbmsh/dsPinch_Group.html
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2142
1357
1144
462
