March 26, 2021 at 3:40 pm
Lovelord
SubscriberHie
I am trying to create an interface between 2 domains i.e., rotating and inertial domain using General Grid Interface connection approach. I want to simulate wind turbine fluid flow using Multiple Frames of Reference (MFR) model . I managed to create the two domains separately, meshed them and now I need to set boundary conditions.
Kindly assist how I can go about using GGI connection in MFR.
Regards
Lovelord
April 1, 2021 at 10:53 pmrfblumen
Ansys EmployeeHi Lovelord,nPlease refer to the CFX tutorial Chapter 14:Flow in an Axial Turbine Stage for basic setup of MFR for a turbine stage. For a steady-state simulation you can either use a Stage interface or Frozen Rotor. For your application, Frozen Rotor would be most applicable. For more details on interfaces for MFR applications, refer to 5.6.3. Using Domain Interfaces in Turbomachinery Applications in the CFX Modeling guide.nViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2688
2130
1349
1136
461
