August 13, 2019 at 9:44 am
rajeshsimhadri
SubscriberHello Everyone
I'm a new user of fluent. I have to simulate magnetic metal chip detector of an aircraft engine oil flow circuit. The magnetic detector should detect and attract any ferrous debris chips present in the oil . Is it right to simulate a particle laden flow (DPM) with magnetohydrodynamic module to realize this flow? I have uploaded the chip detctor image for your reference. -
August 13, 2019 at 12:01 pm
DrAmine
Ansys EmployeeYou can use MHD with DPM. The DPM trajectories will be influenced by the magnetic field. The effect of the volumetric charge on the electric field is neglected and if important you need to code it. But you can first start using the default models.
August 13, 2019 at 12:12 pm
rajeshsimhadri
SubscriberDear Sir
Thanks for your help. I could not find any tutorial online in this domain . As I'm new to fluent could you please show a tutorial of simple dpm fluid flow in a pipe under magnetic field influence. Thanks again -
August 13, 2019 at 5:30 pm
desouzadacosta
SubscriberHi
FYI there is a single tutorial in the customer portal: fluent 15.0
Best -
August 14, 2019 at 4:44 am
rajeshsimhadri
SubscriberHi Sir,
Thanks for your help. I have searched for the tutorial in the customer portal, but couldn't find one. Can you please share the link for the same.
August 16, 2019 at 9:13 pm
desouzadacosta
SubscriberSearch with the keyworrds mhd example
The tutorial is for version 15.0
2656
2120
1347
1118
461
