March 19, 2021 at 4:24 pm
riccardocasula
SubscriberHi,nI want to run the micro-LED example and I am following the steps given in the Lumerical support page, but apparently there is an error in the first script file:nError: ~/STACK_micro_LED.lsf line 52: in stackpurcell: argument 5 must be one of matrixn Error: ~/STACK_micro_LED.lsf line 52: the argument list for the stackpurcell command is incorrect - expect 4 to 6 arguments, types matrix,vector,vector,vector,[vector,int]nAlthough being new to Lumerical, I see the error seems a syntax problem but I don't see there is one and what I can actually do to fix it. Could you help? For reference the Line 52 isnstackpurcell(n,d,f,z,orientation,res)nand it seems to me that the arguments are the type as per the error above.nMany thanks!n
Viewing 0 reply threads
Trending discussions
- Error on Lumerical device
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
