micro-mixing
    • lucaavv
      I need to study micro-mixing in a reactor with model like the engulfment, is these already in Fluent or can I add this somehow?
      Do you mean you're looking at a micro device or you want to look at fine detail of mixing? Please can you elaborate on the "engulfment" model, I've not heard of it but equally it could be a translation issue.
    • lucaavv
      I'm studying a micromixer device and I would like to use the "Engulfment Deformation Diffusion" model
      by Baldyga and Bourne (1984) for the mixing in the microscale or another model for micromixing.
      There is a way to introduce another differential equation in Fluent?
      If you need extra variables then the User Defined Scalars ought to do the job, you'll need to code up their interaction with the species concentrations etc and then hook that into the material properties.
      I'd suggest starting with the model and use the normal diffusion terms to get an idea of what the results are before writing the additional models via User Defined Functions.
    • lucaavv
      Thank you
Viewing 4 reply threads
