Micropile soil Interaction
    • Rania
    • John Doyle
      If you switch frictional to bonded and switch out the soil material with linear elastic (as a test), does that solve? If not, what is the error message? If bonded solves with the soil, maybe you need larger pinball radius for frictional contact along with many more substeps and turn on unsymmetric solver (NROPT,unsym). If bonded fails with soil, perhaps your soil material model needs work. I am assuming that all the nodes at the base (soil and micropile) are fully fixed, but that is not clear to me. n
    • Rania
      thanks for your comments, I run a linear analysis with bonded contact, the model run successfully, I run the model again with large pinball radius, and i still get the same errors, I appreciate your suggestionsn
