Midsurfacing Problem
    • Muhammed
      Hello.
      I’m trying to make a structural analysis with shell model. Solid model shown in the below.
    • peteroznewman
      There is no problem. That is how shell elements work, that display is normal and expected. Turn off the Thick Shells and Beams on the display and it will show the midsurfaces if you don't like the appearance with thick shells turned on.n
    • Muhammed
      Thanks for your prompt response!n
