Minimum fluidization velocity
    • harishravikale.201ch024
      I am simulating a 2D fluidized bed(gas-solid),using eulerian-eulerian multiphase model and syamlal-o'brien drag model. The initial volume fraction of solid is 0.6. I need to find the minimum fluidization velocity but i am not sure how to do it. I tried searching for formula for using empirical relations to calculate it. The value of inlet velocity(gas),i got after calculating was low and i am not sure about the percentage error. Another way to calculate minimum fluidization velocity would be to plot change in pressure across bed vs superficial velocity but i am not sure how to do it in Ansys Fluent. Any help would be appreciated.
      I'd use a hand calculation to find the minimum fluidisation velocity. Pretty sure it's covered in the Chemical Engineering text books, and no doubt also available on the internet.
      There are many emipirical relations,which vary based on mant factors like diameter of particle,density and bed voidage. I have tried calculating using empirical relations and ended up getting velocity as low as 0.003m/s. I got 0.037m/s after using an approximation of the Ergun equation but that was for smaller particles of lesser density. I read somewhere that a 5% error in minimum fluidisation velocity is observed while simulating it online. So i tried it with 1.5*0.037m/s. Didn't seem right.
      It's also dependent on the depth of bed as that'll hold the rest of it down. What do Coulson & Richardson or Perry have to say on the subject? They're text/reference books, no idea if they're on line.
Viewing 3 reply threads
