August 3, 2019 at 3:02 pm
ozankekul
Hello My Friends,
When i simulated combustion , i' m getting this error. I could not solve the problem. if you have any idea to solve the problem, please help me .
Minimum PDF table enthalpy exceeded in 440233 cells on zone 3.
3 1.0000e+00 5.3769e-03 4.8057e-03 4.7646e-03 3.9369e-04 4.6813e-04 4.1865e-02 1.3330e-03 1.6278e-03 2.8901e-02 1.5330e-01 66
1 497
Minimum PDF table enthalpy exceeded in 450349 cells on zone 3.
4 1.0000e+00 2.3754e-02 2.1790e-02 2.1719e-02 2.7465e-04 3.9081e-04 3.8083e-02 7.1038e-04 2.4419e-04 1.0250e-02 1.5734e-01 6:470 496
August 5, 2019 at 10:01 am
Ansys EmployeeCheck the range you set for the pdf table: you may need to alter the limits.
August 6, 2019 at 3:06 pm
August 6, 2019 at 3:16 pm
Ansys EmployeeWhat is the inlet temperature? Have you plotted temperature contours on the domain?
August 6, 2019 at 3:27 pm
ozankekul
SubscriberBoth air inlet temperature and fuel inlet temperature is 300 K . Also temperature of combustor wall is 300 K. Since i have stopped the calculation i don't have the temperature contours of domain. I'm sharing my boundary conditions below. And even if i got this error, i wont stop the calculation and i will share temperature of the domain with you after i had received the solution.
February 19, 2020 at 4:21 am
johnleo
SubscriberHey! Did you solve that problem? My current problem is kind of same like you and facing the same issue. Please let me know if you went through it.
February 19, 2020 at 11:11 am
Ansys EmployeeIf you're fixing the wall temperatures check that's a valid assumption, then work through the other boundary values & model settings.
2524
2066
1279
1096
457
