March 10, 2021 at 4:59 pm
Daedalus
SubscriberIs there a minimum pressure limit in Fluent?nMy simulation result of a system of gas going into 0.01[Pa] vacuum produced result where all the low pressure regions have a pressure of 1[Pa].n -
March 11, 2021 at 2:17 pm
Karthik R
AdministratorHello,nGenerally speaking - yes, there is a limit for Minimum Absolute Pressure. You should be able to find this under Solution -> Control -> Limits. nnIt is possible that you are seeing this result because Fluent is reaching the limit and is not allowing you to go below this. You should see warning messages appear in the console. Please check this.nKarthikn
Trending discussions
Top Contributors
2524
2066
1285
1096
459
Top Rated Tags
