May 19, 2021 at 11:08 am
mi.fura
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHello.
When mirroring an assembly, some sub-assemblies break, not only in the new mirror assembly but also in the original. I am attaching a 3D model and pictures where you can see the problem. What does error message mean in attachment? Everything was drawn in version Ansys SpaceClaim 2021 R1. What can cause this problem?
Thank you.
Â
Best Regards
Â
Miki
May 19, 2021 at 12:49 pm
Subashni Ravichandran
Ansys EmployeeHello Miki
Can you please try right-clicking on the assembly and "Internalise all" and try mirror again?
May 20, 2021 at 12:12 pm
June 7, 2021 at 12:33 pm
I checked with my team on this one. It seems to me that if that option works for you it should not cause any problem.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- problem to access on the spaceclaim help
- Discovery Getting Crashed
- Dwg export error
- Critical error
- BUG to correct is important
- Error messages running solver
- Discovery Live freezes with multiple load cases while topology optimization
- Unexpected graphics error
3638
2502
1733
1226
578
