January 28, 2021 at 4:09 pm
clabr
SubscriberHi everyone,
I need to compute results of a simulation on specific surfaces of my geometry.
The geometry consists of a small tube with side-holes put inside a bigger conduit.
January 28, 2021 at 4:50 pmRob
Ansys EmployeeIf you have holes from one pipe to the other it may be easier to just slice the volume at a mid-hole position radially. Surfaces then exist in CAD and can be labelled for easy post processing. nIf imprint is doing something odd check the scale of the stl coming out of Solidworks. Fluent defaults to metres so there's a good chance the surfaces are either tiny (mm) or huge (km). nJanuary 29, 2021 at 11:06 amclabr
SubscriberThank you for your answer.nIf I make them in CAD then I think I will have new edges at the side holes and they will have an influence on my mesh.nI checked the scale by importing the stl in SpaceClaim together with the geometry. The scale seems fine but surfaces are shifted. I have tried just on the tube for semplicity.nnn
And the same happens in fluent: n
n
January 29, 2021 at 11:36 amRob
Ansys EmployeeWhere's the origin in Solidworks compared to SpaceClaim? I wonder if you've got an offset for some reason. nJanuary 29, 2021 at 12:17 pmJanuary 29, 2021 at 2:53 pmRob
Ansys EmployeeAnd if you export those faces from SpaceClaim as stl? nJanuary 29, 2021 at 4:30 pmclabr
SubscriberIt worked!! Thank you!nViewing 6 reply threads- You must be logged in to reply to this topic.
5386
3375
2471
1310
1022
