Missing alternating stress mean stress under engineering data
    • nrj0025
      I have recently downloaded Ansys and was trying to do some static structural analysis on Nitinol SMA. I couldn't find nitinol as a material in the database so I have been trying to follow a tutorial that I had found for implementing nitinol data to create it. But the tutorial requires adding alternating stress mean stress data but I seem to not have that as an option under the life tab when creating new material. So I was wondering if there is an option to add it or if it is an option that is lacking in the student version of Ansys.
      Thanks
    • Karthik R
      Administrator
      Moving this question to the Structural Mechanics page in the hope that your question finds some visibility.
      Thank you.
      Best,
      Karthik
    • Wenlong
      Hi nrj0025,
      Here is the SMA material reference:https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_mat/smas.html?q=SMA
      Can you please explain what alternating stress and mean stress is and why they are needed to define SMA? I don't recall an SMA material model need such information. Here are the inputs needed for Shape memory effect. If you are to model the superelasticity, then you need a different set of inputs.
      Wenlong
      Useful Links
