Discovery Import
Discovery Import
Missing Edges in drawing
    • mu
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      can you help me to undestand why in the attached file the edges indicated by arrows in the following image are not visible?
      Thank you in advance for your cooperation,
      Best Regards,
      Marco Ugolotti
    • Charudatta Bandgar
      Hello Marco Ugolotti
      Let me check this, I will get back to you,
      Regards.
      Are you using Graphics hidden lines removed?
      Even I am seeing this issue, let me check with the team, and see what could the problem be. Although with the view being rotated, the edges can be seen.
      But the bottom view in this case is still not showing the edge.
      Regards.
      • mu
        Thank you Charudatta Bandgar ,
        yes, we are using hidden lines removed. About using the rotate view in this case it works, but unfortunately it happens on some other drawings and if the model is not symmetrical we can't do that.
        I verified this strange behaviuor: in the pipe, under the weldment, there is an hole (selected in the below image). If you delete the hole the missing line is shown. Obviously the hole is needed, and this cannot be a solution, but can you check if this behaviuor can help to understand why the line is missing?
        Thank you,
        Best regards,
        Marco
        Marco Ugolotti Yes. I can see this behaviour as well. I will get back to you after discussing it with the team.
        Regards.
