Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Missing fields solutions in optimetrics
    • Giorgio Bonomo
      I am using Ansys Electromagnetics Suite Release 2022 R1 (Build 2021-11-22).
      After completing an analysis with a frequency sweep, i try to do an optimetrics sweep over a post-processing variable. When setting up a calculation (Setup Sweep Analysis -> Calculations -> setup calculations) I can select only one frequency (34.5GHz).
      Optimetrics calculation setup
      However I am sure that there actually are field solutions saved at multiple frequencies from the last performed analysis. I can check this in the fields calculator:
      fields calculator
      Why does the frequency selection look that much different between the fields calculator and the optimetrics calculation?
      Thanks for your help
      Giorgio
    • Karthik R
      Administrator
      Hello Giorgio,
      We are responding to your question here.
      Missing fields solutions in optimetrics (ansys.com)
      Thank you!
      Karthik
