Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Missing fields solutions in optimetrics
    • Giorgio Bonomo
      I am using Ansys Electromagnetics Suite Release 2022 R1 (Build 2021-11-22).
      After completing an analysis with a frequency sweep, i try to do an optimetrics sweep over a post-processing variable. When setting up a calculation (Setup Sweep Analysis -> Calculations -> setup calculations) I can select only one frequency (34.5GHz).
      However I am sure that there actually are field solutions saved at multiple frequencies from the last performed analysis. I can check this in the fields calculator:
      Why does the frequency selection look that much different between the fields calculator and the optimetrics calculation?
      Thanks for your help
      Giorgio
    • Ivonne Marti
      Hi Giorgio, could you please specify which tool are you using inside the Ansys Electronics Desktop (Maxwell, HFSS ...)? Thank you. Ivonne
    • Giorgio Bonomo
      Sorry I forgot to mention that, I am using HFSS in Ansys Electronics Desktop 2022 R1
    • Aymen
      Please make sure you save the fields in the frequency sweep before starting the simulation:
Viewing 3 reply threads
