August 29, 2023 at 4:30 am
veerpal kaur
SubscriberHello, I was workshop attendee at University of toronto ON 15-19 May, 2023. I am following vertical detector design and analysis file as you reported on the website. I am unable to find exact file as mention on blog.
- Link for vertcal detector(https://optics.ansys.com/hc/en-us/articles/360042957893-Vertical-photodetector)
- Mentioned step to calcualate response to use this file:
- Run the script vpd_CHARGE_steady_state.lsf. Note the value obtained for dark current at -1V.
- But in download folder, there is not such file.
- Kindly help me to complete the step 2 of result and analysis part.
August 29, 2023 at 7:01 pm
August 30, 2023 at 12:51 am
veerpal kaur
SubscriberThank you Amrita
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7584
4434
2951
1422
1322
