Discovery Import
Discovery Import
missing files
    • bonora.e
      When opening a project I get this error mesage,
      Files that may be repairable in the Files pane (View > Files):
      \intra.proxicad.itdata-z-dfsWorkOthersComec3DFEMTRAVE_SMONTAGGIO_LITE_FINALtrave_smontaggio_final_filesdp0StudyAIMphysics3SolutionController.log
      \intra.proxicad.itdata-z-dfsWorkOthersComec3DFEMTRAVE_SMONTAGGIO_LITE_FINALtrave_smontaggio_final_filesdp0StudyAIMphysics3Controller.scdb
      Files or folders that can be replaced using your file system:
      \intra.proxicad.itdata-z-dfsWorkOthersComec3DFEMTRAVE_SMONTAGGIO_LITE_FINALtrave_smontaggio_final_filesdp0StudyAIMphysics1file1.log
      but even looking at the help I'm not able to understand how to repair the project
      please could you help me in that?
    • Naresh Patre
      Hello proxicad
      I think I am seeing this error for the first time. Were you able to save the concerned project successfully earlier? Or, are you trying to open the project which got crashed?
      I see that the project is located on a network drive. Can you copy it on your local machine, then try opening it in Discovery AIM and see if you experience same issue? Also, is this issue specific to this project or with other projects too?
    • bonora.e
      Hi Naresh
      the project crashed (it crashes systematically when I use face to edge contact, but this is a different story...)
      I have the same message if I work on local drive
    • Naresh Patre
      Hello proxicad
      Since the project crashed and it's now throwing errors while opening, I am afraid if it can be recovered. If you are able to send the project, I can check it at my end if it can be opened.
      Regarding the crash issue, you mentioned that it crashes systematically when I use face to edge contact. Is it something which can be reproduced? If yes, can you share the details?
    • bonora.e
      Hi NAresh,
      after a couple of days working on the project the message disappeared with no action on my side
    • Naresh Patre
      Hello proxicad
      So is the project opening successfully at your end?
    • bonora.e
      yes it's ok now
Viewing 6 reply threads
