Missing Material in temperature plot on a plain
    • John Miller
      I experienced some strange behaviour in result plotting.
      My model generates an extruded material path with ealive.
      The Path dimension is right but in the temperature plot on a plain, some material is missing.
      I don’t know why.
      Is that a bug?
      With best regards
      John
    • Rahul Kumbhar
      Are there killed elements in this region?
      • John Miller
        the elements are not killed.
        Everything in the black rectangle is alive.
        If you see the black the elements are active there, you can see it in the last temperature plot.
        Only the temperature plots on a plane are showing the missing volume.
        With best regards
        John
