Missing Motion.h for motion UDF compilation
    • TONY ARHUR
      Hello please I am compiling a UDF for rotating screws but I receive an error message which indicates the motion.h is missing. Please where can I get this header.
      Did you #include it?  Single screw or interlocking?
    • TONY ARHUR
      Please I am working on interlocking screws
      And did you #include that header?
    • TONY ARHUR
      Yes. I did include the motion.h in the script but it seems it can not be located on my file path
      Did you compile the UDF?
    • TONY ARHUR
      I am trying to compile the script using the fluent setup but I received this error code which indicates the motion.h cannot be located
      I assume the solver is set to 3d and transient? Which moving mesh macro are you using?
    • TONY ARHUR
      I am using the built in compiler for this so I have not specified the mesh macro
      In the .c file, what's the motion macro? Ie DEFINE_GRID_MOTION etc.
    • TONY ARHUR
      Can I send the script over for u to have a look please
      You can post it here, but I (and other Ansys staff) will only have a quick look as we don't debug code. Others aren't similarly constrained, but their participitation is voluntary.
    • TONY ARHUR
      #include "udf.h"
      #include "motion.h"
      DEFINE_CG_MOTION(rotating_screws, dt, vel, omega, time, dtime)
          Thread *t;
          cell_t c;
          real omega_z1 = 300 * 2 * M_PI / 60;  // Rotational speed for screw in rad/s
          real omega_z2 = 200 * 2 * M_PI / 60;  // Rotational speed for screw-2 in rad/s
          /* Loop over all cell threads */
          c_thread_loop_c (t, dt)
              /* Loop over all cells in the cell thread */
              begin_c_loop (c, t)
                  /* Update the rotation of the cell centroid based on the angular velocity for screw */
                  C_CENTROID(c, t)[0] += omega_z1 * dt * (C_NORMAL(c, t)[1] * (C_CENTROID(c, t)[2] - 0.0)
                                                       - C_NORMAL(c, t)[2] * (C_CENTROID(c, t)[1] - 0.0));
                  C_CENTROID(c, t)[1] += omega_z1 * dt * (C_NORMAL(c, t)[2] * (C_CENTROID(c, t)[0] - 0.0)
                                                       - C_NORMAL(c, t)[0] * (C_CENTROID(c, t)[2] - 0.0));
                  C_CENTROID(c, t)[2] += omega_z1 * dt * (C_NORMAL(c, t)[0] * (C_CENTROID(c, t)[1] - 0.0)
                                                       - C_NORMAL(c, t)[1] * (C_CENTROID(c, t)[0] - 0.0));
                  /* Update the rotation of the cell centroid based on the angular velocity for screw-2 */
                  C_CENTROID(c, t)[0] += omega_z2 * dt * (C_NORMAL
      I'm not sure you can calculate both motions in one macro, you may need two DEFINE_CG_MOTION sections. Compare with the example to see if there's anything else you need to do.
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_udf/flu_udf_DynamicMeshDEFINE.html%23flu_udf_sec_define_cg_motion
    • TONY ARHUR
      My main problem has to do with the fatal error that says: motion.h file not found. I have check the installation directory and I could not find the header file "motion.h". Please where can I get this file.
      I don't have that file in my install, so maybe the error is non-diagnostic.
      And review the example - is this the macro you should be using?
Viewing 15 reply threads
