November 7, 2018 at 9:55 am
AsliAla
SubscriberHello,
I am trying to analyze an airfoil as 2D. Meshing process was completed well. Then I made name selection for boundary inlet and airfoil wall. But when I go to the setup part, I could not see airfoil wall and boundary inlet on boundary conditons. Could you please help me?
November 7, 2018 at 10:01 am
Ansys EmployeeWhich solver are you using?
November 7, 2018 at 10:04 am
AsliAla
SubscriberI am using Fluid Flow (Fluent)
November 7, 2018 at 10:53 am
Ansys EmployeeOK, they should transfer then. If you click on the named selected in Meshing have you got "transfer to solver" (or whatever it's called) set to yes?
November 7, 2018 at 11:33 am
AsliAla
SubscriberI got the message that said "The mesh translation to Fluent was successful. "
November 7, 2018 at 2:42 pm
Ansys EmployeeThat means the mesh is OK for Fluent. What surface labels have you got in Fluent?
November 12, 2018 at 6:31 am
Keyur Kanade
Ansys EmployeeWhen you create named selection, please avoid to use spaces in the names.
As Rob has already pointed out, please click on NS. Then check in its details - 'transfer to solver' is set to yes.
In Fluent you would be able to see them in Set up - Boundary conditions.
November 18, 2018 at 11:56 am
AsliAla
SubscriberI put name selection on geometry section and my problem solved. Thank you for all your answers.
March 31, 2019 at 9:05 am
entropyboi
SubscriberMay I ask what do you mean by putting the name selection on the geometry section? I am facing a similar issue, in which I can't find my boundary conditions in my setup despite having created the name selections. I am also using FLUENT, and my settings for the name selections are exactly the same as yours in the photo attachment.
March 31, 2019 at 12:32 pm
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
