December 3, 2022 at 1:21 pm
Patrickodon
SubscriberHi lads/ladies,
I'm mixing two fluids in a process very similar to the Eulerian Multiphase Granular tutorial (not sure where it is online to link, sorry), but I can't get my different surfaces to interact with each other. I have a thin layer of calcium on top, which I'm trying to mix with a cylinder of Hydrogel via a stirrer bar at the bottom.
I've tried multiple times on Inventor and DesignModeler. My latest iteration has been to create three surface patches on Inventor, import as a STEP file into Ansys, create three surfaces in DesignModeler, then create Named Selections in Mesh:
In Fluent, I then change the Type-Wall of the Named Selections to Type-Interface:
(I've tried creating a Wall all around my part, and Interfaces where I want the fluids mixing)
but then come across a variety of issues:
(Second image is error when I try to Run Calculation)
What do I need to do to "Assign" the interfaces?
When I was initially running the solution, before adding Interfaces, the model would run fine, but not mix (presumably as I had Walls instead of Interfaces). I'm at my wit's end with this, any help is hugely appreciated.
December 6, 2022 at 1:16 pm
Vivek Praveen
Ansys EmployeeHi Patrickodon,Take a look at this tutorial: This can explain how to create interfaces in a moving mesh framework.Also, have a look at this approach: -
December 6, 2022 at 1:41 pm
Murari Iyengar
You will get this message when there is a border where no interface has been set. Please check your mesh thoroughly once more.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2142
1355
1144
462
