March 17, 2021 at 8:12 pm
Raj007
SubscriberMarch 18, 2021 at 2:43 amKeyur Kanade
Ansys EmployeeYou may need to do share topology in DesignModeler or Spaceclaim. nPlease check following videosnDM Share Share,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynnMarch 20, 2021 at 5:54 pmRaj007
SubscriberHello,nI have applied shared topology before the start of the simulation. I am afraid that is not the problem.nMarch 22, 2021 at 8:25 amKeyur Kanade
Ansys EmployeePlease check if it is successful. nIn meshing, please check if you have only one face at those places.March 22, 2021 at 10:29 amRaj007
SubscriberHello,nI have given shared topology before starting the simulation. I am afraid it is not the problem.nnMarch 22, 2021 at 4:34 pmRob
Ansys EmployeeThe interfaces mean that the mesh is not connected, or rather is not continuous. Check the geometry so see what is and isn't connected. Which tool are you meshing in? nThe walls are part of the interface:if the interface doesn't fully overlap those walls stop flow escaping from the domain. nViewing 5 reply threads- You must be logged in to reply to this topic.
2600
2088
1319
1108
459
