May 26, 2023 at 1:41 pm
SAEED OMAR
SubscriberHi
I am trying to simulate an antenna inside phone. The assembly size is 160 mmx80mmx8mm. I am trying to simulate the antenna across broad bandwidth (60GHz-100GHz). single adaptive freqeuncy around 80GHz. I am having RAM issue where i get out of memory. I tried to run the simulation in cluster with 500GA of RAM. I am still getting out of memory error.
any suggestions ?
thanks
May 29, 2023 at 2:14 pm
Chinmay T
Ansys EmployeeHello,
Please check that you have enough disk memory/space on your PC to simulate this model.
At what stage of analysis you are getting this problem? Also, share the error screenshots.
Thank you,
Chinmay -
May 29, 2023 at 3:32 pm
SAEED OMAR
SubscriberI am getting error during lambda refinement
Here is a screenshot of the file when I am ruuning in the cluster (500 GA of RAM).
https://photos.app.goo.gl/XgSqGrHkDmGzMCyu5
Here is another screenshot when I am running in my computer(around 64GA of RAM)
https://photos.app.goo.gl/CV2aT2VGZpKowFhg6
- Maxwell, HFSS or Q3D?
- Error
5290
3311
2469
