TAGGED: HF-transformer, maxwell-excitations, maxwell-pemag
October 19, 2023 at 9:13 pm
October 24, 2023 at 10:30 am
Timos
Ansys EmployeeHello, you can calculate the magnetomotive force of the magnetic circuit by drawing a line in the middle of the magnetic flux path and integrating H along it. This can be done in the Fields Calculator in the following way:
1. Choose Quantity > H
2. Select Geometry > Line > your_line
3. Choose Vector > Tangent
4. Select Scalar > Integrate
5. Add > H_dl > OK
This process will give you the MMF for the path you have defined. You can repeat this process for each layer of your planar transformer to get the MMF for each individual layer. Please note that this method is based on the assumption that the magnetic circuit is in 2D XY. If your transformer has a different configuration, you may need to adjust the method accordingly.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8700
4658
3151
1672
1446
