August 19, 2019 at 8:40 pm
hhusker
SubscriberHi,
I am trying to run Modal acoustic analysis for this periodic structure. I keep running into errors. I also tried running normal modal analysis. Both times "unknown error occurred during solution" is brandished.It would be greatly helpful if I could troubleshoot this. I also have the ACT extension,If that makes a difference.
the error is
*** ERROR *** CP = 21.141 TIME= 16:29:23
This model contains the viscous damped materials in a modal analysis
without selecting the damped eigen solver (MODOPT,DAMP). The WB user
must suppress the viscosity assigned to the acoustic region in the WB
Engineering Data, if the viscosity is ignored.
Thank you,in advance.
August 19, 2019 at 8:52 pm
HuiLiu
Ansys EmployeeHi hhusker,
The default engineering data contains viscosity. You can suppress them from engineering data before you run the model. Otherwise, you'll need to switch to damped solver for your modal analysis, under analysis setting.
August 20, 2019 at 2:34 am
hhusker
SubscriberI did try damped solver.but then ends up with 9 warnings and the solver still doesn't produce the solution. I got it running if i suppress the acoustic body in modal analysis. Wouldn't that be a problem if I couple for harmonic an use acoustic body?
August 20, 2019 at 3:25 am
hhusker
SubscriberShould I suppress the material or can we suppress just viscosity?
August 20, 2019 at 2:07 pm
HuiLiu
Ansys EmployeeYou can just suppress the viscosity.
August 21, 2019 at 8:58 pm
hhusker
SubscriberI did that but the error comes asking to neglect thermal conductivity. Even after that it refuses to run,there are no errors but 9 warnings in the soln information.
2092
1321
1108
459
