Tagged: #modal-#, ansys, ansys-mechanical, ansys-workbench, modal-analysis, structure
November 10, 2018 at 11:10 am
Luis
SubscriberHello everyone,
I was wondering why in the modal analysis module I have the possibility to insert loads (such as rotational velocity etc.) even though in this kind of analysis they aren't taken into account.
Thank you
Luis
November 10, 2018 at 4:30 pm
Rohith Patchigolla
Ansys EmployeeLuis,
Rotational velocity load is used in Modal analysis to include the gyroscopic effects.
From Help:
For a rotating structure or machine component, the gyroscopic effects resulting from rotational velocities are introduced into the modal system. These effects change the system's damping.
For a Modal Analysis, Rotational Velocity is valid only when the following Analysis Settings properties are specified:
Damped is set to Yes in the Solver Controls group.
Coriolis Effect property is set to On in the Rotordynamics Controls group.
2138
1355
1140
462
