TAGGED: #modal-#, ansys, ansys-mechanical, ansys-workbench, modal-analysis, structure
November 13, 2019 at 1:51 pm
Cri1994
SubscriberHi everyone,
I'm doing modal analysis about a simple component. the component is a bar ( 40X16X500 mm).
I have a question for you.
The modal analysis launched with a bar in steel(2,512Kg) gives me these modes: 51,914 Hz, 128.95 Hz, 323Hz.
The modal analysis launched with a bar in magnesium alloy ( m=0,576Kg) gives me these modes: 52.337 Hz, 130,08 Hz, 326,43 Hz.
I think that it is non normal. What could be the problem? The materials settings?
Thanks a lot for your time
Cristiano
November 14, 2019 at 2:00 am
SubscriberModal frequency is proportional to sqrt(K/M).
K is proportional to Young's Modulus.
Ratio of Steel to Magnesium Young's Modulus is 2e11/4.5e10 = 4.44
Ratio of Steel to Magnesium Density is 7850/1800 = 4.361
Expected Ratio of Modal Frequency Steel to Magnesium = sqrt(4.44/4.361) = 1.01
This tells me that the modal frequencies being almost the same is expected.
3367
2471
1310
1022
