July 29, 2019 at 9:16 pm
AbdulahALMUTAIRI
SubscriberHi All,
Hope you are well
I am using Workbench to get the natural frequencies for the rail as is it shown in the below screenshot
I have tested the rail in Free-Free boundary condition in the lab where it is supported by foam and modelled it in Ansys workbench in Free-Free condition (without any restrictions on the boundary condition) and I got similar result with error percentage (difference) from 1% to 4% for the first 5 modes . when I modelled the rail where it is placed on hard wood sleepers (where it is placed in the lab, second boundary condition) the model result are completely different from the experiment result.
Can any one please help me wither is my boundary condition in Ansys is wrong or there is a problem in my contact (connection between the rail and the sleepers).
current Boundary condition : Fixed support
July 30, 2019 at 5:27 pm
Wenlong
Ansys EmployeeHi,
Thanks for the interesting post.
It would be easier to give an opinion if we can know the experiment settings. For example:
- Is the rail fixed to the wood? or it is resting on the wood and there is no bonding in between?
- Are you measuring the natural frequency of only the rail or the whole system (rail + wood)? In the current simulation you have, you will get the natural frequency of the whole system.
Bests,
Wenlong
July 30, 2019 at 5:55 pm
AbdulahALMUTAIRI
SubscriberDear wenzhang
Thanks for your interaction
* The Rail in the lab is just resting on the wood sleepers, and the sleepers is resting on the ground.
* I am measuring the whole system natural frequencies
I have already measured the rail in Free-Free boundary condition (without sleepers) + no restrictions on the boundary condition in ansys
Best regards -
July 30, 2019 at 6:43 pm
Wenlong
Ansys EmployeeIn this case, I would suggest frictionless or frictional contact instead of bonded contact. And you probably need to change the fixed boundary condition as well.
Bests,
Wenlong
July 30, 2019 at 6:46 pm
AbdulahALMUTAIRI
SubscriberThank you
But what should I put the boundary condition ? Other than fixed from bottom of the sleepers?
Regards -
July 31, 2019 at 1:11 am
SubscriberModal analysis is a linear analysis. That means ANSYS has to convert a nonlinear contact into a linear contact to do the modal analysis. Therefore a frictional contact that is closed is automatically converted into a bonded contact to do the modal analysis. That is why you get the unrealistic simulation result you show in this image.
It would be easier to match lab data to simulation data if instead of a wide flat wooden sleeper, you put a narrow rod under the rail. Then in the simulation, you could split the face where the rod touches the rail, and make that split line a remote displacement and constrain just 3 DOF and leave the rest free. Then you don't need the sleepers in the model at all.
July 31, 2019 at 1:54 am
Wenlong
Ansys EmployeeOops, Peter is right. Frictionless and frictional contacts are nonlinear contacts, and in modal analysis, we can only have linear contacts.
July 31, 2019 at 2:34 am
AbdulahALMUTAIRI
Thank you peter for explaining
But how can is it possible to replace the sleepers with a rod? I have inserted the sleepers material property in the Engineering data and if I change the geometry of the sleepers the mechanical properties will change. Is it possible please if you can explain it with an example ? I would really appreciate it
August 2, 2019 at 3:11 pm
AbdulahALMUTAIRI
Hi peter
I could not understand your idea, because my experience is limited in this subject
is it possible please if you could illustrate your idea with an example
it would be really helpful
August 2, 2019 at 5:33 pm
Subscriber -
August 3, 2019 at 12:14 am
AbdulahALMUTAIRI
Dear Peter
I can not replace the wooden sleepers with cylinder rods because I want to investigate the rail behaviour when it is supported by the wooden sleepers.
I have included in the engineering data the sleepers material properties
is there any other way ?
Thank you very much
August 3, 2019 at 2:24 am
SubscriberYou studied the agreement between a rail supported by foam and a free-free modal analysis.
I suggest you study the agreement between a rail supported by rods and a remote displacement supported modal analysis.
This is one step closer to support on sleepers, but is easy to do in the lab and in simulation.
Putting a rail on a wooden sleeper without any other constraint may not be that different to the rods.
If there is a significant difference, then you can no longer use modal analysis. You need to run a full transient analysis that can have frictional contact between the sleeper and the rail. How do you excite the rail in the lab? Do you hit it with a hammer? You will have to have an impact in the transient simulation. Extracting the data from the simulation will be similar to extracting data off the rail in the lab. How did you determine the frequency and mode shape in the lab?
But in reality, the rail does not rest on the sleeper, there are spikes that hold it down. When are you going to add the spikes?
August 3, 2019 at 2:56 am
AbdulahALMUTAIRI
SubscriberHi peter
Thanks for your grate support in helping solving this problem
*Using instrumented hammer ( excitation points are only at the top face of the rail )
* YES
* Using a laser vibrometer (capturing the response only in the vertical direction with its software ( it can give you : time domain or frequency domain )(FFT&FRF)
* The study considers just the rail resting on the sleepers without adding any spikes.
August 3, 2019 at 4:35 pm
SubscriberI recommend you build the modal analysis model using remote displacement BCs and see how close it comes to the lab results of the rail resting on the sleepers. I expect it will be closer than the first trial you did with contact.
Then you can do all the work needed to simulate a full Structural Transient model and strike the rail with a hammer and simulate the ringing while extracting all the vertical displacements to feed that simulation data into the software that computes mode shapes and frequencies.
August 3, 2019 at 5:07 pm
AbdulahALMUTAIRI
SubscriberHi peter
So you mean I have to first try remove the sleepers and replaces them with a remote displacement by splitting the bottom face of the rail at the place where the sleepers ?
but what about the sleepers engineering data ?
it will not be included in the model, I mean is it will be logical ?
Thank you
August 3, 2019 at 7:31 pm
So you mean I have to first try remove the sleepers and replaces them with a remote displacement by splitting the bottom face of the rail at the place where the sleepers?
Yes, that is what I mean. You don't have to do it, I just think it is a good idea because it is quick and easy compared with the next logical step.
Will not be relevant to this model.
If the model matches the experimental data better than your first model, then it is a better model.
August 4, 2019 at 1:08 pm
AbdulahALMUTAIRI
SubscriberHi peter
I tried the Structural Transient, because it allows frication contact between the rail and the sleepers
the BC for the sleepers (bottom face ) I have put a displacement on the sleepers and made it free in all directions except Y direction to simulate its BC in the lab, and also simulate the hammer impact using nodal force, the solution took 9 hours to finish and the result was not realistic, when I play the animation video the rail was flying away from the sleepers, I copied the time domain result (time S vs Acceleration mm/s^s) and then using MATLAB to get FFT
the results was completely unrealistic
August 4, 2019 at 2:22 pm
August 4, 2019 at 6:51 pm
SubscriberYou need two remote displacements, not one. Delete the one you have because it has created a reference point between the two faces.
Pick one face, create a remote displacement and set X,Y and Z to 0 and Rotation Z to 0 and leave the other two rotations Free.
Pick the other face, create a remote displacement, set X,Y to 0 and Rotation Z to 0 and leave all others Free.
2098
1327
1110
461
