Discovery Import
Discovery Import
Modal Analysis Error
    • rohandixit1987
      I would like to do Modal Analysis on a part in Discovery LIVE. The imported file is solid. However, I am unable to do Modal Analysis. Kindly refer attached image.
      Please explain how to proceed further.
      Thanks,
      RD
    • Naresh Patre
      Hello RD
      From the image, it looks like the geometry is made up of thin sections which are not getting captured in Discovery Live. Can you try running the case with maximum fidelity and see if it helps to capture the thin regions? You may also want to go through below article on thin geometry features.
      Discovery Live: "Thin" geometric features and relative GPU adjustments
