Discovery Import
Discovery Import
Modal analysis – frequency values repeated
    • susy.johnston
      Hi, I am running a modal analysis (ANSYS AIM) using hollow bodies (manually inserted thickness)  and the frequency results are the ones in the pic attached. But when I run the same sim using solid bodies, the frequency values change and mode shapes as well.   Can anyone explain why this is happening? What's the source of this issue?
    • Charudatta Bandgar
      Hello SJ ,
      I tried recreating the issue on my end with a simpler model, and I got results similar. I will investigate this further and will get back to you with more information as soon as possible.
      Regards.
    • susy.johnston
      Hi Charudatta
      do you have any updates regarding this issue?
