Modal analysis in workbench
    • MemoriseXuxu
      Here I meet a problem about the damping modal in Workbench (ANSYS 18) .
      First,
      how does the software calculate the stiffness coefficient ? I have found some guidance in this link but the result is not correct.
      Second,
      I follow this public essay and I want to redo what he has done. But he only give the parameter above so I have a doubt that the parameter is enough to calculate.
      Hopefully I can get your guidance!
      Thanks all guys!
    • sk_cheah
      Damping ratio is mode dependent. You could try approximating it via the stiffness and mass coefficient. Please see here for some documentation.
      Kind regards,
      Jason
    • MemoriseXuxu
      But I also need to calculate the parameter using Damping Ratio so that I can calculate the stiffness and mass coefficient. So here the problem is still about the frequency the Ansys defined.Because the frequency above is a range of frequency but not a specific number.
