March 24, 2023 at 9:43 pm
March 27, 2023 at 7:41 pm
Mike Rife
Ansys EmployeeHi Maria
What material model is assigned to the first part in the model?
March 29, 2023 at 12:50 pm
March 29, 2023 at 3:20 pm
Mike Rife
Can you post more details on the model setup. I've not been able to reproduce this.
March 30, 2023 at 2:31 pm
March 30, 2023 at 3:32 pm
Mike Rife
Ok - but the idea was to review the model that you had set up. Will you be posting screen shots of that?
March 30, 2023 at 4:05 pm
Maria Fernanda Velasquez
SubscriberHi MikeThe idea is to verify the results of the model in ANSYS, with the example I sent in the image.and no screenshots will be published, I just want to verify results. -
March 30, 2023 at 4:26 pm
Mike Rife
Ansys EmployeeMaria
Ok - the title of your post suggests you were attempting an modal analysis. But then the UCSD model is a harmonic load solved with a time transient analysis (maybe - we have to infer from variables that may or may not actually be used). And you are essentially asking if your model is set up correctly...but without seeing the model, how are we to offer any advice?
March 30, 2023 at 6:14 pm
March 30, 2023 at 7:04 pm
Mike Rife
Your opening statement "To do a harmonic analysis, you must first do a modal analysis,..." is not true. Mode superposition is just one method to solve an harmonic analysis. There are four other methods. This is a great example of why we need to actually see the model set-up...there are too many variables (modeling options) to guess an issue/solution.
Which version are you using? Which modal solver? What is the geometry type? Plane or Shell? If Plane what type (plane stress, axisymmetric, etc)? What is the boundary condition?
March 31, 2023 at 9:46 pm
SubscriberHi MikeThank you very much for your helpThe following are answers to your questionsWhich version are you using?ANSYS 2022 R1Which modal solver?Program ControlledWhat is the type of geometry, plane or shell? If planar, what type (plane tension, axisymmetric, etc.)?Plane Stress (see image)What is the boundary condition?Is fixed at the lower edge
Thanks
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5380
3363
2471
1310
1022
