March 11, 2022 at 9:09 am
Cheerla_ganesh
SubscriberHi all
I'm running a modal Analysis, I have fixed at some bolting locations where motor is mounting, i have extracted 10 modes
but my first mode i was getting 0Hz.
In the motor i have modelled bearing by adding Stiffness using contacts.
But why first frequency is 0 HZ
Could you please help me in this
March 11, 2022 at 12:27 pmjonsoln
SubscriberA 0Hz mode means rigid body motion. You need to double check your connections and boundary condition. The deformation plot should show you which part and in which direction it is moving.
March 11, 2022 at 12:33 pmAniket
Ansys EmployeeThanks ! You are absolutely right! Animating first mode deformation results along with the details will provide which body is underconstrained.
Please see if the following course is useful to you:
Topics in Modal Analysis - ANSYS Innovation Courses
-Aniket
March 23, 2022 at 5:33 amCheerla_ganesh
SubscriberThanks a lot clearing the doubt,I have got the result
2656
2120
1349
1118
461
