December 26, 2022 at 5:21 pm
ILYA Giri
SubscriberHello Everyone.
I am performing modal analysis of a rubber which is limited on the sides by steel strips and has frictionless contacts between them.
Also, the rubber is loaded 20 kg above and has displacement with limit vertical movement.
When I play animation I see that the rubber goes into 2 of 4 steel strips (the last pic below). Other 2 strips it gets around well.
Mesh is pretty fine I guess.
Could you please tell me what I do wrong?
December 26, 2022 at 9:08 pm
SubscriberInsert a Contact Tool under the Connections folder and check if that contact is closed.
December 27, 2022 at 6:17 pm
December 27, 2022 at 6:32 pm
SubscriberTry the following on the contacts that failed.
- Flip the Target-Contact sides on the contacts that are failing.
- Increase the Pinball Radius on the contacts that are failing.
- Change the Behavior to MPC which allows you to visualize the contact elements after the solution when you click on the Solution Information and click on the Graphics tab (after the screen flips to the Worksheet tab).
- If all that fails, open the geometry in SpaceClaim and use the Share button on the Workbench tab to create Shared Topology, then delete all the Contacts.
December 29, 2022 at 5:16 pm
ILYA Giri
SubscriberOk. Thank you. I will try it.
January 9, 2023 at 6:25 am
ILYA Giri
SubscriberHello Peter.
Could MPC be used only with bonded contact? When I set up MPC with frictionless it lights yellow and contact has question mark.
January 9, 2023 at 7:15 am
January 9, 2023 at 1:43 pm
SubscriberI missed that you wanted frictionless contact between the rubber and steel. Shared Topology is like Bonded contact. MPC is only for Bonded Contact.
Frictionless contact is converted to No Separation in Modal if the contact is closed. Make sure the Pinball radius is large enough so that all the nodes are closed.
January 9, 2023 at 6:42 pm
January 9, 2023 at 9:40 pm
SubscriberThat looks good. Ansys automatically chooses which way to set the Target/Contact side and makes the opposite Inactive.
2088
1319
1108
459
