March 19, 2021 at 8:35 pm
njkr224
SubscriberI have been having an issue similar to this for 2 weeks now. I will have a perfectly working Static Structural system; however, when I connect an Eigenvalue buckling system or a Modal system to that Static Structural system and attempt to solve it failed to do so. I have removed personal mistakes from the equation by downloading a similar system with Modal analysis from my textbook's author that solves without error until it is run on my computer. I apologized if this is the wrong section of the forum to post this. I am not sure it a license issue or a physics issue. For your information, I am on the student version 2021 R1. I attached the Solver Output from the fail Modal Analysis.
March 20, 2021 at 3:35 pmpeteroznewman
SubscribernPlease insert the image from Workbench of the Modal system or Eigenvalue Buckling system attached to the Static Structural system. What links did you include between the two systems?nViewing 1 reply thread- You must be logged in to reply to this topic.
2524
2066
1285
1096
459
