Modal Analysis – Supernode
    • Kerber
      I am using 19.2 Workbench and i am surprised that SuperNode is not a default solver for this analysis. I used program controlled setting and i am not sure what would be a default solver.nAfter opting for supernode solver my time to solve a 2 millions element model (using 16 cpu cores) dropped from 8.9hrs to 0.4hrs!! difference between program controlled and supernode was only 0.01HRZ. WOW!n
    • Aniket
      Please check the following page if you have not already:nTypically, the following conditions must be met for the Supernode eigensolver to be most efficient:nThe model is a good candidate for using the sparse solver in a similar static or full transient analysis (that is, the model is dominated with beams/shells or has a thin structure).nThe number of requested modes is greater than 200.nThe beginning frequency input via MODOPT is zero (or near zero).n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
